Component: LED Multicolour RGB (5mm, PCB) ()
Author Matrix
Version 1.2
Category
LED Multicolour RGB (5mm, PCB) component
A simulatable RGB LED in a standard 5mm through-hole PCB mount package. Three port pins each output a simple PWM signal - one for each of the primary colours. The colors can then be mixed in any proportions to allow the desired color to be produced.
Please click here to download the component source project: FC_Comp_Source_RGB_LED_5mm.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RGB_LED_5mm.fcfx
Pin Connections
Red
Pin that the red LED is connected to.
Green
Pin that the green LED is connected to.
Blue
Pin tha the Blue pin is connected to.
Misc
Polarity
Active High: Use for common cathode LEDs - Pin true = LED On. Active Low: Use for common anode LEDs - Pin false = LED On.
Color bit size
Color bit depth. Sets the resolution of the virtual PWM signals driving the LEDs. Lower values mean that the 'Tick' macro can be called less often, but reduced the number of colours that can be created.
Rollover value
The number of unique colours each R/G/B channel can output. Range: 0 to (Rollover Value - 1).
