| Author
Matrix Ltd
| Version
1.3
| Category
Potentiometer (Colour) component
Potentiometer with black plastic knob with coloured cap. Cap and pointer colours can be changed in component properties.
6, 6.0, 05-12-24, MW,Icon edited so compatible with dark theme
Potentiometer Example
Start Angle
| Angle the control points to at its lowest setting. Measured counter-clockwise from the positive x-axis.
Sweep Angle
| Angle through which the control sweeps as it turns from minimum to maximum.
Cap Color
| Colour of the knob cap.
Pointer Color
| Colour of the knob pointer.
Retain Value
| If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
| Analogue input channel - which pin is the analogue input conected to?
Settings
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ACD input to charge before starting the analogue sample.
Bit Depth
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095
Please click here to download the component source project: FC_Comp_Source_pot_Colour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Colour.fcfx
