| Author
Matrix Ltd
| Version
23.0
| Category
Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
20, 20.0, 02-08-24, MW, Added an aditional font count of 4, total font count of 8
23, 23.0, 28-11-24, MW, Fixed error trap for lines when y = 0
23, 23.0, 28-11-24, MW, Fixed shapes colour background not working
23, 23.0, 29-11-24, MW, Fixed initial background colour not working
24, 23.0, 18-03-26, BR, Added DrawBezier function
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightOff
BacklightOff
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
| Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT
X0
| Start X coordinate
- UINT
Y0
| Start Y coordinate
- UINT
CX
| Control point X coordinate
- UINT
CY
| Control point Y coordinate
- UINT
X2
| End X coordinate
- UINT
Y2
| End Y coordinate
- UINT
Resolution
| Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
LCD_Write_Data8
LCD_Write_Data8
- BYTE
data
LCD_Write_Reg
LCD_Write_Reg
- BYTE
data
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
SetDisplayOrientation
- BYTE
Orientation
SetExternalFont
SetExternalFont
| Allows one of the default external font files to be switched out for a different font file.
- BYTE
FontIndex
| Range: 0 to (FontCount - 1)
- STRING
Filename
| New font filename
- BYTE
CharacterSpacing
| Number of pixel columns to use between each character
- BYTE
SpaceWidth
| Number of pixel columns to use for a space character
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Flip X
| Flips the horizontal display axis in hardware.
Flip Y
| Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
| No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Write (WR)
Read (RD)
Use CS
| Determines if ther CS pin is used or is connected to ground and always enabled
Toggle CS
| Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
| Chip select pin connection
Reg Select (D/C)
| Instruction / Command pin connection
Use Ports
| Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Data[7:0]
Use Reset
| Determines if the reset pin is used or if it is simply connected to VCC
Reset
| Reset pin connection
Use Backlight Pin
LED
| LED backlight strobe pin connection
Fonts
Font Count
External Fonts
| Defines how fonts are stored when compiled to a microcontroller. No - Font data is stored in the microcontroller ROM. Yes - Font data is stored externally on a file source such as an SD card.
Font 0
Font
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Component Label
Component Label Scale
Physical Orientation
Export Binary Fonts
| Allows all selected fonts to be exported as a binary format that can be loaded from an SD card. When set to yes loops through all selected fonts and outputs .bin files into the project directory. May take some time to complete, resets back to no when complete.
Please click here to download the component source project: FC_Comp_Source_GLCD_ILI9488.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ILI9488.fcfx
