| Author
Matrix Ltd
| Version
2.2
| Category
Alphanumeric
LCD I2C (Backpack) component
Standard alphanumeric LCD based on a standard I2C control bus. Usually using either a PIC device or Microchip IO expander IC.
Please click here to download the component source project: FC_Comp_Source_LCD_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_I2C.fcfx
A simple example that shows how to use some common functions.
Backpack LCD Example
If the display is not showing the expected characters, the I2c address or contrast could be wrong.
It's best to keep the jumper connected since the backlight is enabled by default.
Using an Arduino Uno the correct I2C address can be determined by using an
IC2 Address Sniffer
The I2C address to use is the one within the first set of square brackets.
For example, with my backpack display, the correct address to use is 0x3F [63]:
The other two Addresses i.e. 0x56 [86] and 0x68 [104] is for my 24C32 EEPROM and DS3231 RTC respectively.
Note The I2c addresses scan will repeat every 5seconds.
The sniffer will send data to your PC via UART to USB.
The Arduino range and clones will have it built-in.
More details on I2C can be found here,
BacklightControl
BacklightControl
- BYTE
State
Clear
Clear
ClearLine
ClearLine
- BYTE
Line
Command
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
- BYTE
instruction
Cursor
Cursor
| Moves the cursor on the LCD Display
- BYTE
x
- BYTE
y
PrintAscii
PrintAscii
| Takes the ascii value for a character and prints the character
- BYTE
character
PrintFloat
PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
- FLOAT
Number
| Enter the number or variable to print to the LCD
- BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
- ULONG
Number
- BOOL
Format
| 0=Signed, 1=Unsigned
| Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
PrintString
PrintString
- STRING
Text
RAMWrite
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
- BYTE
Index
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
- BYTE
position
- BYTE
direction
SetI2CAddress
SetI2CAddress
| Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
- BYTE
Address
| New I2C Device Address excluding R/W bit - Range 0 - 127
Start
Start
| Startup routine required by the hardware device.
I2C Config
LCD Address
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
LCD Configuration
Rows
Columns
Use Backlight
| Controls if the backlight is controlled as part of the main data routine or if it is handled separately.
Component Label
Component Label Scale
Text Colour
Text Background
| Colour surrounding the font characters drawn on the display
Display Background
| Colour of the background of the display
Simulate Comms
| Allows the communications to be simulated via an injector component.
