API Scope
Revision as of 13:51, 29 May 2013 by JonnyW (talk | contribs) (XML import of latest API)
<sidebar>API contents</sidebar> Data scope additions
Functions provided for this class
AddGroup Adds a group to the scope to which streams may be added
AddStream Adds a stream to the given group suitable for inputs and operations
AddBuffer Adds a fixed-view stream to the given group suitable for inputs and operations
AddPort Adds an input to the stream from a port
AddAnalog Adds an input to the stream from an analog channel
AddCustom Adds an input to the stream from a custom injection
AddOp Adds an operation to act on the inputs of the stream
SetBuffer Sets the contents of a snapshot stream
SetCustom Sets one of 32 custom analog values for the group
GetOutputBlock Gets a block of the output stream with each input sample operated on, returns number of samples read
FindOutput Searches back through the output history for a value, returns offset of found sample from TimeUS, 0 if not found
Constants provided for this class
Used by AddOp()
Type Name Value Description
LONG Op_Bound 1 Bound the current value to the expected range of the input
LONG Op_Scale 2 Divide the current value to the expected range of the input
LONG Op_Xor 3 Exclusive-or with the provided integer argument
LONG Op_AndNot 4 Clear the bits in the provided integer argument
LONG Op_And 5 Isolate only the bits in the provided integer argument
LONG Op_Orr 6 Set the bits in the provided integer argument
LONG Op_Not 7 Invert (ones-compliment) the current input
LONG Op_Add 8 Add the argument to the current input
LONG Op_Sub 9 Subtract the argument from the current input
LONG Op_Mul 10 Multiply the argument by the current input
LONG Op_Div 11 Divide the current input by the argument
LONG Op_Pow 12 Raise the input to the power of the argument
LONG Op_Neg 13 Negate (twos compliment) the current input
LONG Op_Recip 14 Perform the reciprocal on the current input
LONG Op_Sqrt 15 Perform a square root on the current input
LONG Op_Ln 16 Perform a natural logarithm on the current input
LONG Op_Ln2 17 Perform a base-2 logarithm on the current input
LONG Op_Cos 18 Convert the input to its cosine value (input is in radians)
LONG Op_Sin 19 Convert the input to its sine value (input is in radians)
LONG Op_Tan 20 Convert the input to its tangent value (input is in radians)
LONG Op_Int 21 Convert the input from a float to an integer (using the floor function)
Used by FindOutput()
LONG Find_Lower 1 Match a search when output is lower than the target value
LONG Find_Equal 2 Match a search when output is equal to the target value
LONG Find_Higher 4 Match a search when output is greater than the target value
LONG Find_LowHigh 8 Match a search when output goes lower to higher than the target
LONG Find_HighLow 16 Match a search when output goes higher to lower than the target
See also
