Component: Thermocouple (MAX31855 / BL0126) (Environmental)
Category Environmental
Thermocouple (MAX31855 / BL0126) component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Version information
8, 1.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
Example program showing how to use the Thermocouple component. MAX31855_Example
Configures the SPI bus ready for communications.
ReadReference_Float
ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
- FLOAT Return
ReadReference_Int
ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
- INT Return
ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
- FLOAT Return
ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
- INT Return
Sample
Sample
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC
Thermocouple Properties
Thermocouple Type
Specified at the end of the MAX part number MAX31855X where X is the Thermocouple type. Selects which type of thermocouple the IC works with.
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31855.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31855.fcfx
