Component: USB HID (Comms: USB)
Version 1.4
Category Comms: USB
USB HID component
Component to create and communicate using a standard HID type USB class. Compatible with simulation and USB enabled microcontroller devices PIC/dsPIC/AVR. Note that AVR is currently in Beta and may have problems with custom descriptors.
Please click here to download the component source project: FC_Comp_Source_USBHID.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBHID.fcfx
Here are some examples to get you started with USB HID communications using Flowcode.
HID Mouse
Reads a EB014 keypad and depending on the key pressed sends the appropriate movement and button clicks to control the mouse.
The speed is set by the speed variable which can range from 1 to 127.
Mouse Keypad Example
Key breakdown: 1 = UpLeft, 2=Up, 3=UpRight, 4=Left, 6=Right, 7=DownLeft, 8=Down, 9=DownRight, *=Left Click, #=Right Click.
Reads two encoders and moves the mouse cursor based on their movement since the last operation.
A switch on pin B0 can be used to toggle the left mouse click on and off and pin B1 can be connected to an LED to show the status of the left mouse button.
The EB073 encoders board connected to PortB will allow all of this functionality.
Mouse Encoder Example
HID Keyboard
Converts a ASCII character into a keypress that will be sent to the USB host device.
A demo string is provided which is then broken down into characters and sent to the USB host.
Keyboard Example
Here is a file showing the standard HID keyboard scan codes to help make sense of the example.
File:HID Keyboard Scan Codes.xls
With the example running if you create a text file and highlight the text file then the USB device will populate the file with data.
E.g.
HelloFromYourUSBKeyboardDevice12345
Currently only compatible with the following characters: 0123456789!"£$%^&*()/\*-+ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\n\t
A complete list of keyboard scan codes can be found here under section 7 - Keyboards.
http://www.freebsddiary.org/APC/usb_hid_usages.php
HID Descriptor Tool
This tool allows you to create your own descriptors which can then be inserted into the HID descriptor property with the custom descriptor type selected.
File:HID Descriptor Tool.zip
CheckRx
CheckRx
Checks for any incoming data. Returns the number of data bytes received since the last check.
Starts up the USB connection and waits for the device driver to be correctly installed on the PC.
ReceiveByte
ReceiveByte
Receives a byte from the USB.
- BYTE Idx
ReceiveString
ReceiveString
Receives a string of bytes from the USB
- BYTE NumBytes
- STRING Return
SendData
SendData
Sends the contents of the transmit buffer to the USB.
SendDataDirect
SendDataDirect
Sends data directly to the USB
- STRING Data
SetSerialNumber
SetSerialNumber
Allows the device serial number to be edited.
- STRING SerialNumber
UpdateData
UpdateData
Allows a byte of the transmit buffer to be assigned.
- BYTE idx
- BYTE value
USB Properties
Vendor ID
USB vendor identifier tied to the manufacturer of the USB device
Product ID
USB product identifier
Device Name
Name used to identify the device
Manufacturer
Manufacturer of the device
Major Version
Firmware major version
Minor Version
Device firmware minor version
Enumeration Timeout
Specifies if the initialise routine is allowed to timeout instead of waiting forever for success
Maximum Current (mA)
Maximum current the host should source to the device - max 500mA
Country Code
Specific country code - if required
Descriptor Select
Built in descriptor selection
HID Descriptor
Contents of the HID descriptor
Subclass
USB Subclass - Normally only mice and keyboards are boot devices
Interface
Standard HID interface type
Transmit Packet Size
Number of bytes to send to the PC
Transmit Period (ms)
Delay between transmit packets
Receive Packet Size
Number of bytes to receive from the PC
Receive Period (ms)
Delay between receive packets
Simulation label used to indicate the USB HID component on the panel.
