Component: Switch Slide (Switch)
| Version | 20.2 |
| Category | Switch |
Switch Slide component
A simple digital slide switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
Library Version, Component Version, Date, Author, Info 10, 10.0, 23-09-24, MW, Fixed a bug to make sure switch starts in the off position 10, 10.0, 23-09-24, MW, Added option for simulation only 10, 10.0, 23-09-24, MW, Fixed a bug preventing custom lable posistion from updating on the fly 11, 11.0, 23-09-24, MW, Fixed connection lable so show correct polariy within array 12, 12.0, 15-04-25, MW, Modified switch to show correct value for off when stating and stopping simulation 12, 12.0, 16-04-25, MW, Fixed a bug where Pin x and y lables remained visisble when supposed to be hidden 13, 18.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size 13, 18.0, 01-05-25, MW, Changed labels so don't interact and change switch state 13, 18.0, 01-05-25, MW, Corrected pin label properties 14, 19.0, 01-05-25, BR, Added option to hide label 14, 19.0, 01-05-25, BR, Fixed SameAsHandle label to update on rename event 15, 19.1, 14-05-25, MW, Corrected switch properties 16, 20.0, 10-03-26, ST, Updated for v11.0.1 mouse event change
Switch Slide Example
(5V / 11K) * 10K = 4.54545V
ReadState
| ReadState | |
| Reads the button state as 0 for released or 1 for pressed Performs debounce if required | |
SetState
| SetState | |
| Sets the switch to be on or off. | |
| State | |
| The new state of the switch (true=on, false=off) | |
WaitUntilHigh
| WaitUntilHigh | |
| Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity | |
WaitUntilLow
| WaitUntilLow | |
| Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity | |
Please click here to download the component source project: FC_Comp_Source_Switch_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Slide_2dgi.fcfx
