API Component.Property.SetValue
Revision as of 14:37, 7 August 2026 by Wiki bot (talk | contribs)
SetValue
Sets a components property as a string
- HANDLE Handle
The component handle of the property owner
- STRING Property
The textual name of the property
- STRING Value
The value to update the property text with (for list properties, this is the 3-digit index)
- NONE Return
This sets the internal value of a property, and compliments GetValue.
Note this call does not set the value the property will evaluate to, but sets the value that will be evaluated.
For example, a port connection property may be set to the string "$PORTA", but this call can not be used to change the value of a port.
When code is generated the value of the property becomes fixed for the generated code corresponding to the last call to SetValue().
  • Add to a calculation icon:
    ::Component.Property.SetValue(handle, "property", "value")
