| Author
Matrix TSL
| Version
1.0
| Category
E-blocks 2
Analogue component
A component to drive the BL0189 Analogue board including Light Sensor, Twin Potentiometers and Thermistor.
GetIntegerTemperature
| Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT
GetRealTemperature
GetRealTemperature
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT
IO_ReadAnalogAsByte
IO_ReadAnalogAsByte
| Reads one of the analogue components as an byte value
- BYTE
| 0 = Light Sensor, 1 = Pot1, 2 = Pot2, 3 = Thermistor
- BYTE
IO_ReadAnalogAsInt
IO_ReadAnalogAsInt
| Reads one of the analogue components as an Integer value
- BYTE
- INT
Analog Connections
Light Sensor
| Analogue Input Channel - Which pin is the analogue input connected to?
Pot1
Pot2
Thermistor
ADC Settings
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Bit Depth
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095
Analog Scope Traces
| Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
Please click here to download the component source project: FC_Comp_Source_EB_Analogue_BL0189.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_Analogue_BL0189.fcfx
