Component: Circular Slider (Graphical Manager Primitives)
Revision as of 10:20, 2 November 2026 by Wiki bot (talk | contribs)
Version 1.1
Category Graphical Manager Primitives
Circular Slider component
A circular slider or circular gauge widget used with the Graphical Manager on the GLCD Layout Editor panel. Indicator = Thumb gives a touchable slider, Needle or None gives a gauge driven by SetSliderValue.
GetID
GetID
Returns the assigned object/widget ID.
GetSliderValue
GetSliderValue
Reads the value of one of the sliders ranging between 0-1 or Custom range Min-Max.
- FLOAT Return
ModifyColour
ModifyColour
Changes the theme index of the selected Object or Widget.
- BYTE Index
0=Thumb/Needle, 1=Background, 2=Low Line, 3=High Line
- BYTE R
- BYTE G
- BYTE B
- BOOL Redraw
ModifyPosition
ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
- INT X
- INT Y
- BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
Changes the width and height of the selected Object or Widget.
- UINT Width
- UINT Height
SetSliderValue
SetSliderValue
Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- FLOAT Value
Range: 0 to 1 - Or Custom Range Min to Max
- BOOL RedrawSlider
0=Do not redraw, 1=Redraw
Line Width
Thickness of the arc in pixels
Indicator
Thumb - a touchable circular slider with a round thumb on the arc
Needle - a circular gauge with a needle from the centre (not touchable) None - a circular gauge showing the value as the filled part of the arc (not touchable)
Indicator Width
Diameter of the thumb or width of the needle in pixels
Indicator Colour
The colour of the thumb or needle
Background Colour
The fill colour of the disc behind the arc
Low Line Colour
Arc colour from the start of the arc (bottom left) up to the thumb
High Line Colour
Arc colour from the thumb to the end of the arc (bottom right)
Touch
Value Range
Custom Range
Minimum Value
The minimum value of the slider.
Maximum Value
The maximum value of the slider.
Please click here to download the component source project: FC_Comp_Source_DC_CircularSlider.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DC_CircularSlider.fcfx
