Component: Compressor (DSP Operators)
Revision as of 10:20, 2 November 2026 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray;" | Category | DSP Operators |} ==Compressor component== Reduces the dynamic range of a signal by turning down levels above a threshold, with adjustable ratio, attack, release and makeup gain. ==Detailed description== ''No detailed description exists yet for this component'' ==Exam...")
Version 1.2
Category DSP Operators
Compress
Compress
Collects a single value from the input buffer, applies the compressor and passes the result to the output buffer.
CompressArray
CompressArray
Passes an entire buffer through the compressor and outputs the compressed version of the buffer at the other end.
ControlCompressor
ControlCompressor
Enables or disables the compressor, enabled by default. When disabled samples pass through unchanged.
- BOOL State
0=Disable, 1=Enable
GetEnvelope
GetEnvelope
Float and 32-bit buffer types only. Returns the detected signal level, measured from the signal centre.
- FLOAT Return
GetEnvelopeInt
GetEnvelopeInt
8/16-bit integer buffer types only. Returns the detected signal level, measured from the signal centre.
- LONG Return
GetGain
GetGain
Float and 32-bit buffer types only. Returns the gain applied on the last sample, excluding makeup gain. 1.0 = no gain reduction, 0.5 = halved.
- FLOAT Return
GetGainQ8
GetGainQ8
8/16-bit integer buffer types only. Returns the gain applied on the last sample in 1/256 steps, excluding makeup gain. 256 = no gain reduction, 128 = halved.
Reset
Reset
Clears the envelope follower so the compressor starts again from no gain reduction.
SetAttackShift
SetAttackShift
8/16-bit integer buffer types only. Sets how quickly the compressor responds to a rising signal. The time constant is 2 ^ Shift samples.
- BYTE Shift
0 = instant, 1 = 2 samples, 2 = 4 samples ... 15 = 32768 samples
SetAttackTime
SetAttackTime
Float and 32-bit buffer types only. Sets how quickly the compressor responds to a signal rising above the threshold.
- FLOAT Time_ms
Attack time constant in milliseconds, 0 = instant
SetMakeupGain
SetMakeupGain
Float and 32-bit buffer types only. Sets the gain applied after compression to restore the overall signal level.
- FLOAT Multiplier
Linear gain multiplier, 1.0 = no change
SetMakeupGainQ8
SetMakeupGainQ8
8/16-bit integer buffer types only. Sets the gain applied after compression in 1/256 steps, e.g. 256 = x1, 384 = x1.5, 512 = x2.
- UINT Gain
Makeup gain x 256, 0 to 8192 (x32)
SetRatio
SetRatio
Float and 32-bit buffer types only. Sets the compression ratio, e.g. 4.0 for 4:1. A level 4dB above the threshold comes out 1dB above it. Large ratios act as a limiter.
- FLOAT Ratio
Compression ratio, 1.0 or greater. 1.0 = no compression
SetRatioShift
SetRatioShift
8/16-bit integer buffer types only. Sets the compression ratio as a power of two: 0 = 1:1, 1 = 2:1, 2 = 4:1, 3 = 8:1, 4 = 16:1, 5 = 32:1, 24 = limiter.
- BYTE Shift
Ratio = 2 ^ Shift, 0 to 5 or 24 for a limiter
SetReleaseShift
SetReleaseShift
8/16-bit integer buffer types only. Sets how quickly the compressor recovers once the signal falls. The time constant is 2 ^ Shift samples.
- BYTE Shift
SetReleaseTime
SetReleaseTime
Float and 32-bit buffer types only. Sets how quickly the compressor recovers once the signal falls.
- FLOAT Time_ms
Release time constant in milliseconds, 0 = instant
SetThreshold
SetThreshold
Float and 32-bit buffer types only. Sets the level, measured from the signal centre, above which compression is applied.
- FLOAT Level
Threshold level in buffer units, must be greater than zero
SetThresholdInt
SetThresholdInt
8/16-bit integer buffer types only. Sets the level, measured from the signal centre, above which compression is applied.
- LONG Level
Threshold level in buffer units, 1 to 65535
Connect To
Buffer Size
Buffer Type
Sets the buffer data type. Automatically matches the type of the input buffer.
Direction
Sets the data direction flow of the component
Compressor
Processing
Set automatically from the buffer type. 8 and 16-bit integer buffers use fixed point maths with no floating point library, ideal for 8-bit devices. 32-bit integer and float buffers use floating point maths.
Signal Centre
Value representing a zero signal. Levels are measured as the distance from this value. Use 0 for signed buffers, or the mid point for unsigned data, e.g. 512 for a 10-bit ADC or 128 for 8-bit data.
Threshold
Level, measured from the signal centre, above which compression starts. 1 to 65535. Uses the same units as the buffer data.
Ratio
Amount of compression applied above the threshold. Fixed point mode works on the linear signal level: the part of the level above the threshold is divided by the ratio. Limiter holds the level at the threshold.
Attack Shift
Attack time constant as a power of two number of samples, 0 to 15. 0 = instant, 1 = 2 samples, 2 = 4 samples, 3 = 8 samples ... Shifts are used in place of multiplies to keep the maths fast on 8-bit devices.
Attack Time (ms)
Attack time constant resulting from the attack shift at the specified sample rate.
Release Shift
Release time constant as a power of two number of samples, 0 to 15. 0 = instant, 1 = 2 samples, 2 = 4 samples, 3 = 8 samples ...
Release Time (ms)
Release time constant resulting from the release shift at the specified sample rate.
Makeup Gain
Linear gain multiplier applied after compression to restore the overall level. 1 = no change. In fixed point mode this is converted to a 1/256 step value when compiled, maximum 32.
Sample Rate (Hz)
Rate at which samples are passed through the compressor. Used to convert between attack and release times and samples.
Please click here to download the component source project: FC_Comp_Source_DSP_Compressor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Compressor.fcfx
