Exercise - Dashboard Panel - Adding Objects
Revision as of 14:38, 1 June 2013 by JohnVerrill (talk | contribs)
Open the Mounted LED flowchart
To do this, click on the down arrow next to 'World size' and select the 'Local scale'option.
Set up the Dashboard Panel
  • Make sure that the Dashboard Panel is visible. If it is not, then click on the View menu and tick the check box next to 'Dashboard Panel'.
  • Select a suitable color for the background, such as dark green (red=0, green=128, blue=0) by clicking on the 'General options' tab.File:Panel Icon GeneralOpts.jpg
Add the switch
  • Click on the 'Inputs' toolbox and locate the 'Toggle Metal Panel' switch.
  • Click on the down arrow next to it and then on the 'Add to dashboard panel' option.
The switch appears at the center of the Dashboard panel.
  • Add a label to identify it (as there will be others!) To do this:
