API Component.Delete
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Deletes an existing object, removing it from the panel
Class hierarchy
Component
Delete
HANDLE Target
The object to delete
BOOL
Returns true if the operation is a success, else false
This deletes a component.
Root components and component definitions may not be deleted. All other components may be deleted.
The components memory may not be freed immediately. The system will queue deleted components and erase the memory when the component is not referenced. Therefore a component may delete itself in its own event macro and safely complete processing.
  • Add to a calculation icon:
    result = ::Component.Delete(target)
