API Component.Property.SetColor
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Sets a components 'color' property as a R,G,B value
Class hierarchy
Component
Property
SetColor
HANDLE Handle
The component handle of the property owner
BYTE Red
The 0-255 red part of the colour
BYTE Green
The 0-255 green part of the colour
BYTE Blue
The 0-255 blue part of the colour
This is a helper function that takes the red, green and blue values form 0-255 and calls SetValue with the property name "color" and the argument the RGB value built from this calls arguments.
No check is made to see if the target Handle has a property called "color", and no error is returned if it does not.
  • Add to a calculation icon:
    ::Component.Property.SetColor(handle, red, green, blue)
