API Connection.SetPort
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Sets a ports value from its index
Class hierarchy
Connection
SetPort
UINT Index
The index of the port or a quoted port name
ULONG Value
The value to set the port to
ULONG Mask
The bitmask for the port
The default value for this parameter is: -1
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Connection.SetPort(index, value, mask)
