API File.NVM.Create
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Creates the new file as a block of non-volatile memory
Class hierarchy
File
NVM
Create
STRING Filename
The name of a new file to create
ULONG Bytes
The number of bytes to fix the buffer to
HANDLE
  • Add to a calculation icon:
    result = ::File.NVM.Create("filename", bytes)
