API Component.Property.SetListItem
<sidebar>API contents</sidebar> Sets an existing list entries text for the property by named index
HANDLE Handle
- The component handle to alter the property of
STRING Property
- The textual name of the property
STRING Index
- The text or integer entry of the property
STRING Value
- The value to update the entry with
Returns true if the operation is a success, else false
Sets the text part of a list property identified by its 3-digit Index'. If the line does not exist this call fails.
Note the Index is not the line of the list to extract, but the 3-digit identifier. If multiple lines have the same identifier this will extract the first found.
To find the index from the line, use GetListIndex.
To add the line to the list regardless of whether it exists, use AddListItem.
- Add to a calculation icon:
result = ::Component.Property.SetListItem(handle, "property", "index", "value")
