API Panel.Position.Animate
Blends positions from two sources to a destination over time
HANDLE Dest
HANDLE Start
- The initial position of the animation
HANDLE End
- The final position of the animation
UINT Millisecs
- Time to take to perform the animation
- The default value for this parameter is: 1000
This call animates between two objects, storing the result in a third Dest position. It performs the operation in the background over a specified time.
The closely related Morph call performs this operation allowing for any point on the scale to be stepped to, but it must be called manually by the user to perform an animation.
Animations can be stopped using StopAnimate
- Add to a calculation icon:
::Panel.Position.Animate(dest, start, end, millisecs)
