API Panel.Graphics.DrawText
Draws a line of text texture
FLOAT X
- Initial horizontal position of text (depends on Align)
FLOAT Y
- Initial vertical position of text (depends on Align)
STRING Text
- The text to draw, may be multiple lines
BYTE Align
- The text alignment
- Typical values for this parameter:
Name Description Align_TopLeft Text is left aligned and drawn below the Y coordinate Align_TopCenter Text is center aligned and drawn below the Y coordinate Align_TopRight Text is right aligned and drawn below the Y coordinate Align_CenterLeft Text is left aligned and vertically centered Align_Center Text is horizontally aligned and vertically centered Align_CenterRight Text is right aligned and vertically centered Align_BottomLeft Text is left aligned and drawn above the Y coordinate Align_BottomCenter Text is center aligned drawn above the Y coordinate Align_BottomRight Text is right aligned drawn above the Y coordinate
- Add to a calculation icon:
::Panel.Graphics.DrawText(x, y, "text", ::Panel.Graphics.Align_TopLeft)
