API File.Create
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Creates the new file as a standard stream
Class hierarchy
File
Create
STRING Filename
A textual filename to create
BOOL Read
Set to enable read access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
  • Add to a calculation icon:
    result = ::File.Create("filename", true, false)
