Changing the Speed of a Simulation
<sidebar>Sidebar: Overview of Simulation</sidebar>
Clock speed
Select the Clock Speed option from the Build -> Project Options menu to change the speed of the simulation. This can be changed using the drop down menu which has options from 1000000 Hz to 40000000 Hz depending on the selected chip, you can also input a value manually by typing in the selected box.
Simulation speed
Simulation speeds can vary from 0.25 Hz (or one simulation every 4 seconds) to 1000Hz (or one simulation every 0.001 seconds). In addition, you can ask Flowcode to simulate the flowchart as fast as possible. When this happens, Flowcode does not update the variables, call stack and microcontroller views whilst it is running but any external component views do get updated.
Configuration information
Select 'Configure' from within the Build > Project Options menu to open the chip download configuration window. A number of options are available that allow you to change download parameters. For details on the various options see Configuring the Chip.
