API Panel.PCloud.UnitScale
Revision as of 20:14, 25 June 2013 by JonnyW (talk | contribs) (XML import of Point Cloud API)
<sidebar>API contents</sidebar> Creates a unit scaled axis (X, Y or Z) with a center of zero and a range of two
Class hierarchy
Panel
PCloud
UnitScale
FLOAT[] Axis
The X, Y or Z axis to adjust
ULONG Offset
The first item in the array to adjust
LONG ArrayStep
The number of elements from the first to the second
The default value for this parameter is: 1
ULONG Elements
The number of points to adjust
FLOAT OrigOffset
Returns the center of the original object
This parameter is returned back to the caller
FLOAT OrigRange
Returns the range of the original object
  • Add to a calculation icon:
    ::Panel.PCloud.UnitScale(_arrayaxis, offset, arraystep, elements, return_origoffset, return_origrange)
