API Panel.PCloud.SetPoints
Revision as of 10:11, 27 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Sets the X,Y,Z point lists
Class hierarchy
Panel
PCloud
SetPoints
HANDLE PCloud
The handle to the cloud to set the points of
FLOAT[] XYZ
The array of (X,Y,Z) coordinates to use
ULONG Elements
The number of (X,Y,Z) points to set
Sets the points in the cloud in a chain layout.
Ordering of points in a chain and grid
The points specified will form the points on a line - this is typically the format used for graphs and clouds rendered with Mode_Point. XYZ is an array with index 0 representing X, 1 representing Y, 2 representing Z and 3 representing the next X point (and so on). If the X, Y and Z are in different locations use SetPointsEx. The Elements represents the number of {X,Y,Z} points to display.
  • Add to a calculation icon:
    ::Panel.PCloud.SetPoints(pcloud, _arrayxyz, elements)
