API File.AbsPath
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
API contents Gets an absolute path from a relative filename
STRING Filename
The path of the file relative to the project file
HANDLE Owner
A component that owns the file if it is a resource
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon: result = ::File.AbsPath("filename", owner)
