API Component.Property.CopyFilter
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Copies a property filter from one target to another
Class hierarchy
Component
Property
CopyFilter
HANDLE Source
The source component to copy from
HANDLE Dest
The target component to copy to
STRING Property
The textual name of the property
STRING
The text copied from Source to Dest.
This copies a properties filter for the named Property from the Source component to the Dest. It is provided for convenience.
An equivalent call using SetFilter from this to a dest component may be:
::Component.Property.SetFilter(dest, "property", this::property)
And from any component to another:
value = ::Component.Property.GetFilter(source, "property")
::Component.Property.SetFilter(dest, "property", value)
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.CopyFilter(source, dest, "property")
