API Panel.Position.SetScale
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets an objects scale based on a position
Class hierarchy
Panel
Position
SetScale
HANDLE Dest
HANDLE Source
The position or component to read from
BOOL
Returns true if the operation is a success, else false
This is equivalent to the call to Set, except that the coordinates and rotation of the position are omitted. These may be set with SetCoords and SetRotation.
This call is useful for building up a position from multiple sources.
  • Add to a calculation icon:
    result = ::Panel.Position.SetScale(dest, source)
