API Panel.Position.SetRotation
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets an objects orientation based on a position
Class hierarchy
Panel
Position
SetRotation
HANDLE Dest
HANDLE Source
The position or component to read from
BOOL
Returns true if the operation is a success, else false
This is equivalent to the call to Set, except that the coordinates and scale of the position are omitted. These may be set with SetCoords and SetScale.
This call is useful for building up a position from multiple sources.
  • Add to a calculation icon:
    result = ::Panel.Position.SetRotation(dest, source)
