API Panel.LinkBar.SetBarGfx
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the graphic for the main line of the bar
Class hierarchy
Panel
LinkBar
SetBarGfx
HANDLE LinkBar
The handle to the bar to alter
ULONG Mode
The graphics mode to draw the bar with
Typical values for this parameter:
Name Description
Bar_None No bar is drawn between the start and end points
Bar_Line A line is drawn connecting the start and end
Bar_Cone A 3D cone is drawn connecting the start and end points
Bar_Cylinder A cylinder is drawn connecting the start and end points
ULONG RGBA
The red, green, blue value to colour the point with
FLOAT Width
The scale to use for 3D modes
This sets the graphics mode for the main line of the bar. The default for the bar is to draw a single pixel line (Bar_Line).
The Mode is the type of link to draw, and if a graphic is to be drawn this will be affected by Width, which is always assumed to be positive and its sign is ignored. The height of the bar is its length, which is auto-calculated.
The RGBA is a true-colour red, green, blue value. This is 255 (0xFF) for red, 0xFF00 for green and 0xFF0000 for blue.
  • Add to a calculation icon:
    ::Panel.LinkBar.SetBarGfx(linkbar, ::Panel.LinkBar.Bar_None, rgba, width)
