API Sound.LoadWav
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Loads a wave file into memory, providing the values needed to play it
Class hierarchy
Sound
LoadWav
STRING Filename
The formatted file to load into memory
BYTE[] Buffer
A buffer to write the wave data to
UINT SampleFormat
Variable to receive the format of the samples
This parameter is returned back to the caller
ULONG Elements
Variable to receive the number of sample elements to play
FLOAT SampleRate
Variable to receive the wave source sample rate
BOOL
Returns true if the operation is a success, else false
This loads WAV files given a Filename to the data. The Filename may point to a resource file. The data in the file should be in a RIFF format, see WAV file for a more detailed description of a WAV file.
On exit from the routine, the Buffer, SampleFormat, Elements and SampleRate are all updated to contain data read from the file. These are all written with zero values (Buffer is not altered) if the call fails.
If Buffer is not large enough for the wave data it is resized in the call to an appropriate size.
  • Add to a calculation icon:
    result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
