API File.Buffer.ReadByte
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Reads a single byte from the input stream, -1 if empty
Class hierarchy
File
Buffer
ReadByte
HANDLE FileHandle
The handle of an open file
ULONG Timeout
A number of milliseconds to wait for the byte to be available
INT
  • Declare a variable 'result' of type INT
  • Add to a calculation icon:
    result = ::File.Buffer.ReadByte(filehandle, timeout)
