API File.Buffer.ReadArray
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Reads an array from the input stream, returns elements read
Class hierarchy
File
Buffer
ReadArray
HANDLE FileHandle
The handle of an open file
ARRAY Buffer
An array of some type to read from the file
ULONG Elements
Maximum number of elements to read
The default value for this parameter is: -1
ULONG Timeout
A number of milliseconds to wait for the data to be available
ULONG
Returns elements read
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.Buffer.ReadArray(filehandle, _arraybuffer, elements, timeout)
