API File.Buffer.WriteArray
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Writes an array to the input stream
Class hierarchy
File
Buffer
WriteArray
HANDLE FileHandle
The handle of an open file
ARRAY Data
An array of data to write to the file
ULONG Elements
Maximum number of elements to write
The default value for this parameter is: -1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.Buffer.WriteArray(filehandle, _arraydata, elements)
