Component: API (ESP32) (API Slave Devices)
| Version | 2.0 |
API (ESP32) component
Connects to an ESP32 device running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ESP32_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ESP32_API_Comp.fcfx
The App Developer (ESP32) component allows an ESP32 board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ESP32 hardware the board must first be pre-programmed with dedicated firmware.
The firmware source project can be downloaded from here.
You will need to set your WIFI SSID and Password near the top of Main to allow the ESP module to connect to your network.
The IP Address to the ESP32 hardware is selected via the SCADA_ESP32 component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the address for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
Please note pins 34, 35, 36, 39 are only capable of digital inputs and cannot be used as digital outputs.
| App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 | 22 | 23 | 25 | 26 | 27 | 32 | 33 | 34 | 35 | 36 | 39 |
| Device Port Pin | A0 | A1 | A2 | A3 | A4 | A5 | A12 | A13 | A14 | A15 | A16 | A17 | A18 | A19 | A21 | A22 | A23 | A25 | A26 | A27 | B0 | B1 | B2 | B3 | B4 | B7 |
| GPIO Number | 0 | 1 | 2 | 3 | 4 | 5 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 | 22 | 23 | 25 | 26 | 27 | 32 | 33 | 34 | 35 | 36 | 39 |
Please note not all analogue input pins are available as peripheral ADC2 is not accesible when WIFI/Bluetooth is active. Only the pins shown are available.
| App Developer Slave Analogue Pin | 0 | 3 | 4 | 5 | 6 | 7 |
| Device Port Pin | B4 | B7 | B0 | B1 | B2 | B3 |
| GPIO Number | 36 | 39 | 32 | 33 | 34 | 35 |
Please note that PWM channels are tied in pairs and so channel 0 and 1 use the same internal timer peripheral. They will always run at the same frequency and when enabling channel 1 channel 0 duty will be reset to 0% and visa versa.
| App Developer Slave Peripheral Pin | I2C 0 SDA | I2C 0 SCL | I2C 1 SDA | I2C 1 SCL | SPI 0 MOSI | SPI 0 MISO | SPI 0 SCK | SPI 1 MOSI | SPI 1 MISO | SPI 1 SCK | UART 0 RX | UART 0 TX | UART 1 RX | UART 1 TX | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | PWM 6 | PWM 7 | PWM 8 | PWM 9 | PWM 10 | PWM 11 | OneWire |
| Device Port Pin | A13 | A12 | A15 | A14 | A13 | A12 | A14 | A23 | A19 | A18 | A26 | A25 | B0 | B1 | A0 | A2 | A4 | A5 | A12 | A13 | A14 | A15 | A16 | A17 | A18 | A19 | A21 |
| GPIO Number | 13 | 12 | 15 | 14 | 13 | 12 | 14 | 23 | 19 | 18 | 26 | 25 | 32 | 33 | 0 | 2 | 4 | 5 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 |
PortA = GPIO pins 0 - 31 : A0 = GPIO 0
PortB = GPIO pins 32 - 39 : B0 = GPIO 32
ADCSample10
| ADCSample10 | |
| Reads the voltage present on an Analog pin as an 12-bit value range 0-4095 | |
| ADCChannel | |
| Range: 0, 3-7 | |
ADCSample8
| ADCSample8 | |
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0, 3-7 | |
ADCSampleArray10
ADCSampleArray8
ADCSampleAverage10
ADCSampleAverage8
ADCSetPrechargeTime
ADCSetReferenceVoltage
| ADCSetReferenceVoltage | |
| Specified the reference setting for ADC reads. | |
| RefType | |
| 0=AREF, 1=VCC, 3=Internal 1.1V | |
I2CInitialise
| I2CInitialise | |
| Initialise the I2C module ready for communications | |
| Channel | |
| Baud | |
I2CReceive
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
I2CRestart
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
I2CSend
| I2CSend | |
| Channel | |
| DataOut | |
I2CStart
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
I2CStop
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
| IOGetInputPin | |
| Pin | |
| Range: 0-29 | |
IOSetOutputPin
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| State | |
| Range: 0-1 | |
OneWireBusReset
OneWireGetDeviceCount
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
OneWireGetIDByte
OneWireInitialise
| OneWireInitialise | |
| Initialise the OneWire module ready for communications | |
| Channel | |
OneWireMatchROM
OneWireReceiveByte
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
OneWireScanBus
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
OneWireSkipROM
| OneWireSkipROM | |
| Performs a bus reset and the sends the SkipROM command byte | |
| Channel | |
OneWireTransmitByte
| OneWireTransmitByte | |
| Transmit a byte to the one wire bus a bit at a time | |
| Channel | |
| Data | |
PWMDisable
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-11 | |
PWMEnable
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
PWMSetDuty
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-11 | |
| Duty | |
PWMSetFrequency
| PWMSetFrequency | |
| Sets PWM frequency in Hz | |
| Channel | |
| Range: 0 - 11 | |
| Frequency | |
| Frequency (Hz) | |
SPIInitialise
| SPIInitialise | |
| Channel | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
SPITransferTrans
UARTBaud
UARTCheckRX
| UARTCheckRX | |
| Channel | |
UARTInitialise
| UARTInitialise | |
| Channel | |
UARTReceive
| UARTReceive | |
| Channel | |
UARTSend
| UARTSend | |
| Channel | |
| Data | |
