Component: Accel / Gyro 6-Axis (Grove 105020012) (Movement Orientation)
Version 1.1
Category Movement Orientation
Accel / Gyro 6-Axis (Grove 105020012) component
Combined 6-Axis Accelerometer and Gyroscope sensors. Useful for working out data such as Pitch and Roll. Can be combined with a Magnetometer to also provide Yaw.
GetAccelReading
GetAccelReading
Collects one of the accelerometer readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
GetGyroReading
GetGyroReading
Collects one of the gyroscope readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
GetTemperatureReading
Collects the Temperature readings from the last sample.
- INT Return
Startup the I2C bus and configure the device. Returns 0 if the device is ok and 255 if the device is not responding correctly.
ReadRegister
ReadRegister
Reads the value from one of the registers onboard the device.
- BYTE Reg
SampleDevice
SampleDevice
Collects the accelerometer, gyro and temperature readings from the device,
WriteRegister
WriteRegister
Sets the value of one of the registers on the device.
- BYTE Reg
- BYTE Data
Device Specific
Gyro Range
Accel Range
Device Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
Chooses the data source for simulation.
Please click here to download the component source project: FC_Comp_Source_AccelGyro_6-Axis_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AccelGyro_6-Axis_Grove.fcfx
