Component: Accel Gyro 6 Axis (MPU-6050) (Sensors)
| Author | Matrix Ltd |
| Version | 2.0 (Release) |
| Category | Sensors |
MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors. Useful for working out data such as Pitch and Roll. Can be combined with a Magnetometer to also provide Yaw.
GetAccelReading
Collects one of the accelerometer readings from the last sample.
- BYTE Axis
- 0=X, 1=Y, 2=Z
GetTempReadingReal
Collects the temperature reading in degrees C as a floating point value.
SampleDevice
Collects the accelerometer, gyro and temperature readings from the device,
GetGyroReadng
Collects one of the gyroscope readings from the last sample.
- BYTE Axis
- 0=X, 1=Y, 2=Z
GetTempReadingInt
Collects the temperature reading in degrees C as an integer value.
ReadRegister
Reads the value from one of the registers onboard the device.
- BYTE Address
WriteRegister
Sets the value of one of the registers on the device.
- BYTE Address
- BYTE Value
Startup the I2C bus and configure the device.
Returns 0 if the device is ok and 255 if the device is not responding correctly.
Simulation macro reference
Address Bit AD0
This property is of type Unsigned integer and can be referenced with the variable name AddressBit.
Gyro Range
This property is of type Fixed list of ints and can be referenced with the variable name GyroRange.
Accel Range
This property is of type Fixed list of ints and can be referenced with the variable name AccelRange.
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Data (SDA)
This property is of type Single digital pin and can be referenced with the variable name SDA.
Clock (SCL)
This property is of type Single digital pin and can be referenced with the variable name SCL.
