| Category | Utility |
Advanced String Functions component
A component designed to add more advanced functions to the existing built-in string library.
Please click here to download the component source project: FC_Comp_Source_AdvancedStringFunctions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AdvancedStringFunctions.fcfx
Explode
The explode functions use a delimiter to split a string up into an array.
For example "1,2,3,4" using the delimiter ',' would create {1,2,3,4}.
Implode
The implode functions do the reverse and create a string from an array.
for example {1,2,3,4} using the delimiter ',' would create "1,2,3,4".
All of the string functions assume that your string variable is large enough to store the data being passed into it. Overflowing the bounds of the string could lead to RAM corruption which could effect the operation of your program.
Contains
|   | Contains |
| Scans a string to see if it contains a specific substring. Returns 1 if found, otherwise returns 0. |
|  - STRING | StrData |
| Data string to scan |
|  - STRING | StrMatch |
| String to look for in the data |
|  - BOOL | Return |
ExplodeToByteArray
|   | ExplodeToByteArray |
| Takes an ASCII string and using a delimiter converts it into an array of bytes. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4} |
|  - STRING | StringInput |
| Data string e.g. "1,2,3,4" |
|  - BYTE | Delimiter |
| Delimiting character byte for example ',' |
|  - BYTE | DataArray |
| Data array to hold the numberic values found |
|  - UINT | MaxCount |
| Maximum number of values to return |
|  - UINT | Return |
ExplodeToFloatArray
|   | ExplodeToFloatArray |
| Takes an ASCII string and using a delimiter converts it into an array of floats Returns the number of values discovered and placed into the DataArray, e.g. "1.1,2.2,3.3,4.4" would become {1.1,2.2,3.3,4.4} |
|  - FLOAT | DataArray |
|  - UINT | MaxCount |
|  - UINT | Return |
ExplodeToINTArray
|   | ExplodeToINTArray |
| Takes an ASCII string and using a delimiter converts it into an array of integers. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4} |
|  - UINT | DataArray |
|  - UINT | MaxCount |
|  - UINT | Return |
ExplodeToStringArray
|   | ExplodeToStringArray |
| Takes an ASCII string and using a delimiter converts it into an array of strings. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {"1","2","3","4"} |
|  - STRING | DataArray |
|  - UINT | MaxCount |
|  - UINT | Return |
FormattedStringFloat
|   | FormattedStringFloat |
| Converts a floating point value to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003" |
|  - FLOAT | Value |
| value to format |
|  - BYTE | MinLength |
| The minimum length you want the string to be |
|  - BYTE | PaddChar |
| Added character to padd the string with e.g. ' ' or '0' |
|  - BYTE | Precision |
| Number of decimal points to add |
|  - STRING | Return |
FormattedStringINT
|   | FormattedStringINT |
| Converts a signed int to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003" |
|  - INT | Value |
| value to format |
|  - BYTE | PaddChar |
|  - STRING | Return |
ImplodeFromByteArray
|   | ImplodeFromByteArray |
| Creates an ASCII string from an array of byte values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4" |
|  - UINT | Count |
| Number of values held in the array |
| Delimiter to add between values |
|  - STRING | Return |
ImplodeFromFloatArray
|   | ImplodeFromFloatArray |
| Creates an ASCII string from an array of float values. Places a delimiter in between each value. e.g. {1.1,2.2,3.3,4.4} would become "1.1,2.2,3.3,4.4" |
|  - UINT | Count |
| Number of decimal points to add to each float value |
|  - STRING | Return |
ImplodeFromINTArray
|   | ImplodeFromINTArray |
| Creates an ASCII string from an array of integer values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4" |
|  - UINT | Count |
|  - STRING | Return |
ImplodeFromStringArray
|   | ImplodeFromStringArray |
| Creates an ASCII string from an array of string values. Places a delimiter in between each value. e.g. {"1","2","3","4"} would become "1,2,3,4" |
|  - UINT | Count |
|  - STRING | Return |
InsertInto
|   | InsertInto |
| Inserts a string into another string at the specified index position. |
|  - STRING | DataString |
| Data string to ammend |
|  - STRING | Insert |
| Data to insert |
|  - UINT | InsertionIndex |
| Index location in the string to insert the data |
|  - VOID | Return |
MemCopy
|   | MemCopy |
| Allows an array of bytes to be copied into another array of bytes at the chosen start address. |
|  - BYTE | SourceData |
| Source data to copy from |
|  - UINT | SourceStartAddress |
| Address in the source to start copying data |
|  - BYTE | DestinationData |
| Data to copy the values into |
|  - UINT | DestinationStartAddress |
| Address in the destination to start inserting data |
|  - UINT | NumBytes |
| Number of values to copy from the source to the destination |
|  - VOID | Return |
PositionOf
|   | PositionOf |
| Scans a string to see if it contains a specific substring. Returns the location in the string if found, otherwise returns -1. |
|  - UINT | SearchFrom |
| Starting index for the search, default 0. |
|  - INT | Return |
RemoveFrom
|   | RemoveFrom |
| Allows a set number of characters to be removed from a starting location in a string. |
|  - UINT | CharsToRemove |
| Number of characters to remove from the string |
|  - UINT | StartingIndex |
| Index location in the string to delete the data |
|  - VOID | Return |
SearchAndReplace
|   | SearchAndReplace |
| Attempts to find a specific string inside the data string and if found replaces with the provided replacement string. Returns the number of times the search pattern was found. |
|  - STRING | StrSearch |
|  - STRING | StrReplace |
| String to insert into the data |
|  - UINT | Return |
|   | Properties |
