Component: Battery Cell Fuel Gauge (MAX1704x) (Electrical)
| Category | Electrical |
Battery Cell Fuel Gauge (MAX1704x) component
Provides accurate voltage and state of charge readings for one or two lithium ion cells. Based on the MAX1704x device range including: MAX17043 MAX17044 MAX17048 MAX17049
ClearAlert
| ClearAlert | |
| Clears the alert status bit, if the voltage is still below the specified threshold level then the alert interrupt pin will fire again. | |
ReadStateOfCharge
| ReadStateOfCharge | |
| Reads the SOC and returns as a floating point value in % between 0 and 100 | |
ReadStateOfChargeByte
| ReadStateOfChargeByte | |
| Reads the SOC and returns as a byte value in % between 0 and 100 | |
ReadVoltage
| ReadVoltage | |
| Reads the voltage and returns as a floating point value in Volts. | |
SetPowerMode
| SetPowerMode | |
| Allows the device to be put to sleep and woken from sleep. | |
| Mode | |
| 0=Awake, 1=Sleep | |
Please click here to download the component source project: FC_Comp_Source_Battery_Cell_Fuel_Gauge_MAX17043_17044.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Battery_Cell_Fuel_Gauge_MAX17043_17044.fcfx
