Component: Bluetooth BLE (ESP32 SPP Client) (Wireless)
Category Wireless
Bluetooth BLE (ESP32 SPP Client) component
Bluetooth BLE client component designed to run on a ESP32 providing GATT SPP functionality. Designed to scan for and connect to an existing Bluetooth BLE GATT SPP server. BT BLE functionality must be switched on via the sdkconfig file.
CheckConnectionStatus
Fc9-comp-macro.png CheckConnectionStatus
Checks to see if the Bluetooth device is connected. Returns 1 if connected.
ConnectToDevice
Fc9-comp-macro.png ConnectToDevice
Manually connect to the specified discovered device. Returns true if the device connected successfully.
Fc9-u8-icon.png - BYTE index
DisconnectFromDevice
Fc9-comp-macro.png DisconnectFromDevice
Manually disconnect from the connected device
GetDiscoveredDeviceCount
Fc9-comp-macro.png GetDiscoveredDeviceCount
Returns the number of discovered devices.
GetDiscoveredDeviceMAC
Fc9-comp-macro.png GetDiscoveredDeviceMAC
Gets the 6 Byte MAC address of the discovered device at the selected index
Fc9-u8-icon.png - BYTE MAC
6-byte Array to return the MAC address into
GetDiscoveredDeviceName
Fc9-comp-macro.png GetDiscoveredDeviceName
Gets the friendly name of the discovered device at the selected index
Fc9-comp-macro.png Initialise
Starts up the Bluetooth communications SPP service.
ReceiveArray
Fc9-comp-macro.png ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
Buffer to place received data into
Fc9-u16-icon.png - UINT MaxBytes
Max number of bytes to try and read within the time
Fc9-u16-icon.png - UINT Timeout
Number of ms to wait for incoming data
ReceiveByte
Fc9-comp-macro.png ReceiveByte
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
ReceiveCount
Fc9-comp-macro.png ReceiveCount
Collects the number of bytes currently stored in the receive buffer.
ReceiveINTArray
Fc9-comp-macro.png ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
Fc9-u16-icon.png - UINT Data
Array to store the incoming data
Fc9-u8-icon.png - BYTE NumValues
Maximum number of values to try and receive
Fc9-bool-icon.png - BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-u8-icon.png - BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveString
Fc9-comp-macro.png ReceiveString
Attempts to receive a string of characters from the Bluetooth SPP. Terminates on timeout, on receiving the MaxBytes or on receiving a '\n' character
SendArray
Fc9-comp-macro.png SendArray
Sends a byte to the Bluetooth serial connection
Data Array to send
Fc9-u16-icon.png - UINT NumBytes
Number of bytes to send
SendByte
Fc9-comp-macro.png SendByte
SendINTArray
Fc9-comp-macro.png SendINTArray
Sends an array of 16-bit integers to the Bluetooth serial connection
Data Array to send
Fc9-bool-icon.png - BOOL MSBFirst
SendString
Fc9-comp-macro.png SendString
Sends a string to the Bluetooth serial connection
Data Array to send
Uninitialise
Fc9-comp-macro.png Uninitialise
Shots down the Bluetooth communications SPP service.
Fc9-type-21-icon.png Receive Buffer
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Fc9-type-21-icon.png Max Discovered Devices
Maximum number of devices that can be detected.
Fc9-type-7-icon.png Filter By UUID
Allows the scan results to be filtered to a specific UUID in the advertisement data
Fc9-type-21-icon.png Service UUID
16-bit value that identifies the custom “Simple SPP” service so scanners know the device supports that feature.
Fc9-type-21-icon.png Characteristic UUID
16-bit value that describes the single characteristic that carries the serial-like data flow (reads, writes, notifications).
Fc9-type-7-icon.png Auto Connect On Match
Auto connect to the first device we find with a matching UUID
Fc9-type-7-icon.png Data Receive Interrupt
Fc9-type-16-icon.png Verbose Debug
When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
