Component: Button helper (Helpers)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Helpers |
- 1 Button helper component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Clear
- 5.2 GetState
- 5.3 GetStateFor
- 5.4 GetTarget
- 5.5 Register
- 5.6 SetAutoReset
- 5.7 SetAxis
- 5.8 SetAxisFor
- 5.9 SetDisabledPos
- 5.10 SetDisabledPosFor
- 5.11 SetEnabledPos
- 5.12 SetEnabledPosFor
- 5.13 SetLatching
- 5.14 SetLatchingFor
- 5.15 SetMode
- 5.16 SetModeFor
- 5.17 SetMovement
- 5.18 SetMovementFor
- 5.19 SetNotify
- 5.20 SetPivotPos
- 5.21 SetPivotPosFor
- 5.22 Unregister
- 6 Property reference
A button overlay that allows any object to behave like a button
Please click here to download the component source project: FC_Comp_Source_buttonhelper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_buttonhelper.fcfx
Clear
|   | Clear |
| Clears all objects from the lists This leaves no links for the button helper | |
|  - VOID | Return |
GetState
|   | GetState |
| Returns true if the button is depressed, else false | |
|  - BOOL | Return |
GetStateFor
|   | GetStateFor |
|  - HANDLE | Target |
|  - BOOL | Return |
GetTarget
|   | GetTarget |
| Gets the target handle the property links to | |
|  - HANDLE | Return |
Register
|   | Register |
| Adds the object to the list if not already there | |
|  - HANDLE | Target |
|  - VOID | Return |
SetAutoReset
SetAxis
|   | SetAxis |
| Sets the movement axis as an Axis_... constant | |
|  - BYTE | Axis |
| Movement axis to set to, default 4 | |
|  - VOID | Return |
SetAxisFor
|   | SetAxisFor |
|  - HANDLE | Target |
|  - BYTE | Axis |
|  - VOID | Return |
SetDisabledPos
|   | SetDisabledPos |
| Sets the position of the released button | |
|  - HANDLE | PositionHandle |
| A handle to the position of the depressed location | |
|  - VOID | Return |
SetDisabledPosFor
|   | SetDisabledPosFor |
| Sets the disabled position for an object | |
|  - HANDLE | Target |
|  - HANDLE | Position |
|  - VOID | Return |
SetEnabledPos
|   | SetEnabledPos |
| Sets the position of the depressed button | |
|  - VOID | Return |
SetEnabledPosFor
|   | SetEnabledPosFor |
| Sets the enabled position for an object | |
|  - HANDLE | Target |
|  - VOID | Return |
SetLatching
|   | SetLatching |
| Sets whether the button is depressed when the mouse is released | |
|  - BOOL | Enabled |
|  - VOID | Return |
SetLatchingFor
|   | SetLatchingFor |
|  - HANDLE | Target |
|  - BOOL | Enabled |
|  - VOID | Return |
SetMode
|   | SetMode |
| Sets the animation mode for the button | |
|  - BYTE | Mode |
| 0=User, 1=Up/Down, 2 = Lever | |
|  - VOID | Return |
SetModeFor
|   | SetModeFor |
|  - HANDLE | Target |
| The target object, 0 for 'set default' | |
|  - BYTE | Mode |
|  - VOID | Return |
SetMovement
|   | SetMovement |
| Sets the movement in units or PI/16 steps for the button | |
|  - FLOAT | Move |
| Movement to set to - default is 4 | |
|  - VOID | Return |
SetMovementFor
|   | SetMovementFor |
|  - HANDLE | Target |
|  - FLOAT | Move |
| Movement to set to, default 4 | |
|  - VOID | Return |
SetNotify
SetPivotPos
|   | SetPivotPos |
| Sets the position of the object the lever rotates around | |
|  - VOID | Return |
SetPivotPosFor
|   | SetPivotPosFor |
| Sets the position the lever rotates around for an object | |
|  - HANDLE | Target |
|  - VOID | Return |
Unregister
|   | Unregister |
| Removes the object to the list if present | |
|  - HANDLE | Target |
|  - VOID | Return |
|   | Properties |
|   | Host component |
|   | Lever pivot |
