Component: Current Sensor (ACS7xx) (Electrical)
Author medelec35
Category Electrical
Current Sensor (ACS7xx) component
ACS7XX range of +/- 5, 20, 30, 50, 100, 150 & 200A current sensors
A simple example shows how to use a ASC712 to measure current range of +/- 5A. The component type can be changed within its properties.
FC6 Icon.png ACS712 example
Current
Fc9-comp-macro.png Current
Current reading in amps
VoltgeADC
Fc9-comp-macro.png VoltgeADC
Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
Fc9-type-16-icon.png Device
Fc9-type-16-icon.png Type
Fc9-type-15-icon.png VDD
For improved accuracy, measure the voltage across the supply of the current sensor, then enter that as VDD voltage.
Fc9-type-15-icon.png Offset current adjust (Amps)
Offset current adjusts the curent output when comparing to a current monitor. For example current from the componet shows 2.0 Amps and curent monitor shows 1.5 Amps. For the current offset enter -0.5
Fc9-type-6-icon.png Channel
Fc9-type-21-icon.png Average Loop (1 - 255)
The more higher the value, the more stable and accurate result would be. Results will take longer. Try 200
Fc9-type-15-icon.png Offset Voltage
The voltage value when no cureent is flowing This is normally 2.5V for bidirectional and 0V for Unidirectional
Fc9-type-21-icon.png Bit Depth
Fc9-type-21-icon.png Sensitivity
Component sensitivity x10
Please click here to download the component source project: FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
