Component: Drawing Area (Graphical Color)
Version 1.6
Category Graphical Color
Drawing Area component
Simulation runtime only graphical display component designed for SCADA operations. Allows easy pixel based displays and support for the GLCD libraries such as bitmap drawer and textfield.
Please click here to download the component source project: FC_Comp_Source_glcd_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_glcd_SCADA.fcsx
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawLineFast
DrawLineFast
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
DrawStart
DrawStart
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
SetBackgroundColour
SetBackgroundColour
- BYTE Red
Range: 0-255
- BYTE Green
Range: 0-255
- BYTE Blue
Range: 0-255
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
Range: 0-255
- BYTE Green
Range: 0-255
- BYTE Blue
Range: 0-255
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Display Method
