Component: File (ESP32 SDMode) (File)
Author Matrix Ltd.
Version 9.9
Category File
File (ESP32 SDMode) component
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Version information
9, 9.0, 04-03-25, MW, Changed tooltips from Not implemented on the RPI to Not implemented on the ESP32
AppendByteArrayToFile
Fc9-comp-macro.png AppendByteArrayToFile
Fc9-u8-icon.png - BYTE Data
AppendByteToFile
Fc9-comp-macro.png AppendByteToFile
AppendFloatArrayToFile
Fc9-comp-macro.png AppendFloatArrayToFile
Adds a binary float array to the end of the file. Returns 0 for success.
Fc9-f32-icon.png - FLOAT Data
Binary data array to append to the file
Number of values to append
AppendINTArrayToFile
Fc9-comp-macro.png AppendINTArrayToFile
Adds a binary INT array to the end of the file. Returns 0 for success.
Fc9-u16-icon.png - UINT Data
Fc9-bool-icon.png - BOOL MSBFirst
0=LSB then MSB, 1=MSB then LSB
AppendLongArrayToFile
Fc9-comp-macro.png AppendLongArrayToFile
Adds a binary Long array to the end of the file. Returns 0 for success.
Fc9-u32-icon.png - ULONG Data
AppendStringToFile
Fc9-comp-macro.png AppendStringToFile
Fc9-string-icon.png - STRING Data_String
CloseFile
Fc9-comp-macro.png CloseFile
CreateFile
Fc9-comp-macro.png CreateFile
DeleteFile
Fc9-comp-macro.png DeleteFile
Fc9-comp-macro.png Initialise
Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail
MoveToNextFileSector
Fc9-comp-macro.png MoveToNextFileSector
Fc9-u8-icon.png - BYTE ForceNextSector
OpenFile
Fc9-comp-macro.png OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
8.3 filename of the file we are trying to open e.g. "file.txt"
OpenFolder
Fc9-comp-macro.png OpenFolder
Fc9-string-icon.png - STRING Folder_Name
ReadByteArrayFromFile
Fc9-comp-macro.png ReadByteArrayFromFile
Reads a binary byte array from the currently open file. Auto increments the position in the file. Returns the number of values read.
ReadByteFromFile
Fc9-comp-macro.png ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
Fc9-comp-macro.png ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
Fc9-u32-icon.png - ULONG Address
ReadFileLength
Fc9-comp-macro.png ReadFileLength
Fc9-s16-icon.png - INT Return
ReadFileSize
Fc9-comp-macro.png ReadFileSize
Reads the entire size of the current file in bytes.
Fc9-u32-icon.png - ULONG Return
ReadFloatArrayFromFile
Fc9-comp-macro.png ReadFloatArrayFromFile
Reads a binary Float array from the currently open file. Auto increments the position in the file. Returns the number of values read.
Data variable to populate with data
Number of values to read
ReadINTArrayFromFile
Fc9-comp-macro.png ReadINTArrayFromFile
Reads a binary INT array from the currently open file. Auto increments the position in the file. Returns the number of values read.
ReadLongArrayFromFile
Fc9-comp-macro.png ReadLongArrayFromFile
Reads a binary Long array from the currently open file. Auto increments the position in the file. Returns the number of values read.
ReadStringFromFile
Fc9-comp-macro.png ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to attempt to read
Fc9-u8-icon.png - BYTE EndChar
Ends the string if the value specified is found, default is 0
SetFileIndex
Fc9-comp-macro.png SetFileIndex
Fc9-u8-icon.png - BYTE File_Index
Range: 0 to 4
Uninitialise
Fc9-comp-macro.png Uninitialise
Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral.
WriteByteToBuffer
Fc9-comp-macro.png WriteByteToBuffer
Fc9-u16-icon.png - UINT Address
WriteFileSector
Fc9-comp-macro.png WriteFileSector
Fc9-type-16-icon.png Frequency
Fc9-type-21-icon.png File Count
Number of simultaneous files we want to access.
Fc9-type-16-icon.png SD Mode
Number of bytes to use as a read buffer to speed up file access.
Fc9-type-21-icon.png Directory Size
Number of bytes to use as a directory buffer to track the current directory.
Fc9-conn-icon.png Pins
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CMD
Fc9-type-5-icon.png D0
Fc9-type-5-icon.png D1
Fc9-type-5-icon.png D2
Fc9-type-5-icon.png D3
Fc9-conn-icon.png Simulation
Fc9-type-20-icon.png Sim Root Folder
The directory used by the simulation to look for files.
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
