| Author
Matrix Ltd
| Version
1.6
| Category
Graphical Monochrome
GLCD eINK (SSD1681) component
Graphical display component based on the SSD1681 monochrome graphical eINK controller IC. Functions without the use of a read pin by hosting the graphical memory using the microcontroller's RAM memory.
Version information
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
| Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT
X0
| Start X coordinate
- UINT
Y0
| Start Y coordinate
- UINT
CX
| Control point X coordinate
- UINT
CY
| Control point Y coordinate
- UINT
X2
| End X coordinate
- UINT
Y2
| End Y coordinate
- UINT
Resolution
| Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
Refresh
Refresh
| Outputs the stored display data to the display
SetBackgroundColour
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetShadeIntensity
SetShadeIntensity
| Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE
Shade
| Range: 1-15 / 1=Dim / 15 = Bright
Dimensions
Pixel Width
Pixel Height
Buffer Size
| Size of the required display buffer in Bytes
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Command (D/C)
Data (SDI)
| Serial data output control pin
Chip Select (CS)
| Chip select output control pin
Serial Clock (CLK)
| Serial clock output control pin
Busy (BUSY)
| Busy pin to determine if the display is busy or available for writes.
Fonts
Font Count
Font 0
Font
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Space Width
Simulation Mode
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_eink_SSD1681.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_eink_SSD1681.fcfx
