Component: RFID (Sparkfun Quiic / ID-12LA) (15209) (Wireless)
(Redirected from Component: ID 055a7ab6 78df 47ca b967 143485c4d706)
| Category | Wireless |
RFID (Sparkfun Quiic / ID-12LA) component
Provides functions to drive the Sparkfun Quiic RFID reader module (ID-12LA). Allowing access to read 125KHz RFID tags. Suitable for applications such as tracking, logging or access control.
Please click here to download the component source project: FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
ChangeI2CAddress
CheckForTag
| CheckForTag | |
| Checks to see if a tag has been detected by the module. Returns 1 if tag has been detected. Tag ID and Time since read can be accessed using GetTag and GetTime macros. | |
GetTag
| GetTag | |
| Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long. | |
| Data | |
GetTagString
| GetTagString | |
| Gets the tag ID returned as a string. Must be called after CheckForTag has returned true. String variable should be at least 13 characters long. | |
GetTimeMS
| GetTimeMS | |
| Gets the time in milliseconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
GetTimeS
| GetTimeS | |
| Gets the time in seconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
| Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored. | |
IsKnownID
| IsKnownID | |
| Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory. | |
RemoveCurrentTag
| RemoveCurrentTag | |
| Removes the current Tag ID from the known tag storage. | |
RemoveTagID
| RemoveTagID | |
| Removes a specific 6-byte tag ID from the known tag storage | |
| ID | |
| Array of 6 bytes containing tag ID | |
StoreCurrentTag
| StoreCurrentTag | |
| Stores the current detected tag as a known tag storage Returns true if the tag has been stored or false if there is no remaining room | |
StoreTagID
