Component: PWM (CAL) (Misc)
(Redirected from Component: ID 068080a0 b949 4a7e b370 c45430e0c9de)
| Version | 2.2 |
| Category | Misc |
PWM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Pulse Width Modulation peripheral.
Version information
Library Version, Component Version, Date, Author, Info 10, 2.2, 04-11-24, BR, Added pin caption to the remap port pin selection property 11, 2.2, 04-11-24, BR, Cleaned up pin caption from none remap port pin property
The ChangePeriod macro must be called at least once before calling the Enable macro to configure and start the PWM timer resource.
ChangeFrequency
| ChangeFrequency | |
| Advanced function for the ESP32 hardware to set the PWM output frequency. | |
| Frequency | |
| New PWM desired frequency in Hz | |
ChangePeriod
| ChangePeriod | |
| Change the Period (and prescaler) for this PWM Channel | |
| period | |
| period value PIC/AVR: 0-255 16-bit PIC: 0-65535 | |
| prescaler | |
| prescaler 1,4,16,64 | |
Disable
| Disable | |
| Disable this PWM Channel | |
Enable
| Enable | |
| Enable this PWM Channel, note the ChangePeriod macro must be called at least once before calling this function | |
GetList
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
GetValue
| GetValue | |
| Returns Named property Value | |
| Name | |
SetDuty10Bit
| SetDuty10Bit | |
| Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535 | |
| duty | |
| Duty value 0 - 1023 | |
SetDuty8Bit
| SetDuty8Bit | |
| Set the Duty cycle (0-255) for this PWM Channel | |
| duty | |
| duty value 0 - 255 | |
SetDutyFloat
| SetDutyFloat | |
| Advanced function for the ESP32 hardware to set the PWM duty as a percentage between 0.0 and 100.0 | |
| Duty | |
SetValue
| SetValue | |
| Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
| Name | |
| Value | |
Please click here to download the component source project: FC_Comp_Source_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PWM.fcfx
