Component: Accel / Gyro / Mag 9-Axis (LSM9DS1 / BL0135) (Movement Orientation)
(Redirected from Component: ID 20699a0c 0925 40c4 8aa1 35f294e225e6)
| Version | 1.2 |
| Category | Movement Orientation |
- 1 Accel / Gyro / Mag 9-Axis (LSM9DS1 / BL0135) component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 CollectXYZData
- 4.2 CollectXYZDataFloat
- 4.3 Initialise
- 4.4 ReadTemperature
- 4.5 Read_Bearing
- 4.6 Read_N_Registers
- 4.7 Read_Register
- 4.8 SetAddress
- 4.9 SimReset1G
- 4.10 SimSetAccelerometer
- 4.11 SimSetCompass
- 4.12 SimSetGyro
- 4.13 SimSetTemperature
- 4.14 UpdateAccelerometerData
- 4.15 UpdateCompassData
- 4.16 UpdateGyroData
- 4.17 Write_N_Registers
- 4.18 Write_Register
- 5 Property reference
- 6 Component Source Code
LSM9DS1 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors Useful for working out orientation data such as Pitch, Yaw and Roll.
CollectXYZData
CollectXYZDataFloat
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
ReadTemperature
| ReadTemperature | |
| Reads the temperature from the sensor and returns the value as an integer. | |
Read_Bearing
Read_N_Registers
| Read_N_Registers | |
| Reads a set of data values from sequential registers on the accelerometer | |
| Start_Reg | |
| Num_Regs | |
| Data | |
Read_Register
| Read_Register | |
| Reads a value from a register on the accelerometer. | |
| Reg | |
SetAddress
| SetAddress | |
| Address | |
| 0=Accelerometer, 1=Magnetometer | |
SimReset1G
| SimReset1G | |
SimSetAccelerometer
| SimSetAccelerometer | |
| Allows the XYZ slider values to be set via the simulation | |
| X | |
| Y | |
| Z | |
SimSetCompass
| SimSetCompass | |
| X | |
| Y | |
| Z | |
SimSetGyro
| SimSetGyro | |
| X | |
| Y | |
| Z | |
SimSetTemperature
| SimSetTemperature | |
| Temp | |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
UpdateCompassData
| UpdateCompassData | |
| Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
UpdateGyroData
| UpdateGyroData | |
| Reads from the gyroscope and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Write_N_Registers
| Write_N_Registers | |
| Writes a set of data values to a sequential registers on the accelerometer | |
| Start_Reg | |
| Num_Regs | |
| Data | |
Write_Register
| Write_Register | |
| Writes a data value to a specific register on the accelerometer | |
| Reg | |
| Data | |
Please click here to download the component source project: FC_Comp_Source_AccelMagGyro_LSM9DS1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AccelMagGyro_LSM9DS1.fcfx
