Component: USB Slave (Comms: USB)
(Redirected from Component: ID 26cbc2df 5ef0 47db ab2f c2425b14462f)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | Comms: USB |
USB Slave component
Component to create and communicate using a generic USB communications profile. Has the ability to allow the device to be a slave to the PC. Compatible with simulation and USB enabled microcontroller devices (PIC/dsPIC).
Please click here to download the component source project: FC_Comp_Source_USBSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBSlave.fcfx
CheckRx
| CheckRx | |
| Called to check if there is any incoming data waiting to be received. Returns the number of incoming data bytes. Only needed when not running the slave service. | |
GetByte
| GetByte | |
| Retreives the byte at location Idx from the incoming data buffer. | |
| Idx | |
| Specifies the location in the incoming buffer | |
GetString
| Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout. | |
RunSlaveService
SendByte
| SendByte | |
| Adds the byte onto the end of the outgoing data buffer. | |
| Data | |
| Data byte to transmit to the host | |
SendByteArray
SendString
| SendString | |
| Adds a string of bytes onto the end of the outgoing data buffer. | |
| Data | |
| Data String To Send | |
| Length | |
| Max number of bytes to try and add to the outgoing buffer. | |
StopSlaveService
