Component: Relay (Grove 103020005) (103020005) (General Output)
(Redirected from Component: ID 2f95990b 1dc6 4cb4 a6b1 e000a487b702)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | General Output |
Relay (Grove 103020005) component
The Relay is a digital normally open switch capable of switching much higher voltages and currents than your normal Microcontroller outputs. When set to HIGH, the LED will light up and the relay will close allowing current to flow. The peak voltage capability is 250V at 10 amps. Simulated component, green indiacator is on when the relay is active.
Please click here to download the component source project: FC_Comp_Source_Relay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Relay.fcfx
SwitchOff
| SwitchOff | |
| Switch off the relay, disconnecting the common pin from the normally open pin. | |
SwitchOn
| SwitchOn | |
| Switch on the relay, connecting the common pin to the normally open pin. | |
| Properties | |
| Control Pin | |
