| Author
Matrix Ltd
| Version
6.0
| Category
Graphical Color
GLCD (ST7735) component
Graphical display component designed to work with the ST7735 16-bit colour graphical controller IC.
Version information
5, 5.0, 27-11-24, MW, fixed vertical line issue
5, 5.0, 27-11-24, MW, fixed some missing pixels with DrawArc
5, 5.0, 27-11-24, MW, Modified properties so all unused pins will be assigned to MOSI pin
5, 5.0, 27-11-24, MW, Fixed SPI issue for non ESP32 targets
5, 5.0, 27-11-24, MW, Fixed when QueueFastPixels is set to no
6, 6.0, 27-11-24, MW, Fixed Bitmap colour depth when used replace option
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightOff
BacklightOff
| Switches off the backlight
BacklightOn
BacklightOn
| Switches on the backlight
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
DrawRoundedRectangle
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
| Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
X Offset
| Horizontal offset before the active display pixels.
Y Offset
| Vertical offset before the active display pixels.
Colour
Monochrome
Foreground Color
Background Color
Invert Colours
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Use SPI
| No - Use dedicated IO pins to drive the display Yes - Use the micrcontroller's SPI peripheral to drive the display
SPI Settings
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
Queue Fast Pixels
| An optimisation for ESP32 based devices where Fast pixels are queued up and all drawn together. Acts to speed up writes to the display when drawing lines, rectangles, ellipses, circles, none transparent strings etc.
Pixel Queue Size
| Defines how many fast pixels can be stored in the queue. The larger the number the more RAM used but the quicker the speed to write to the display. Each pixel = 2 bytes.
Use CS
Toggle CS
| Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Chip Select
| Chip select pin connection
Use Reset
Reset
| Reset Pin
Use Backlight
Backlight
| Backlight Pin
DC
| Data/Command Pin
Fonts
Font Count
Font 0
Font
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7735.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7735.fcfx
